24p footage digitized w 2:3:3:2 pulldown
J5 squared
I was jus handed a project with the media already digitized. Problem is that right away i noticed weird fielding issues. I looked at the footage is shown as lower fielded and was digitized as dv inserting 2:3:3:2. Well the footage was shot 24p. So the footage should have been digitized normal dv. The way i see it inserting the wrong pulldown is going to cause all sorts of issues and the footage should be redigitized, does anyone know of a way to get around redigitizing though? Were on a bit of a time crunch here.
i dunno now that i think about this more maybe that isn't a problem? when u digitize 24pa u still take a 29.97 stream in and then fcp looks for flagged frame frames correct? So if theres no flagged frames than the footage would jus be normal 29.97? In looking at his sequence settings on the inital edit they started i'm thinking thats where the problem really lies and they may have lucked out on the footage. But if thats the case why have two settings for digitze 24p, why not always digitize as 24pa and then if theres no flagged frames ur fine... am i in the correct line of thinkin on this?
I'm kinda confused by your situation... do you mean that the video was shot in 24p and captured with the Advanced Pulldown Removal? I'm pretty sure that FCP would automatically abort since the pulldown flags wouldn't match. Check the framrate of the video, is it 23.98 or 29.97?
you don't insert pulldown when capturing, you remove it if necessary.
I know you don't, but i didn't capture the footage someone else did. I looked at his settings and it was set to remove 2:3:3:2 advanced pulldown. And thats what he said it digitized at. But yes it was shot 24p NON advanced.
open up the files he gave you in quicktime and post what the framerate is.
If it is 29.97 then you will not need to recapture, if it is 23.98 then you will have to (if in fact the wrong pulldown was removed)...
