24p capture question
sean_king
I shot at 24p Normal and captured the footage using Final Cut Pro's
Easy Setup DV-NTSC 24p (23.98). When I export a Quicktime movie (using
the Current Settings) all of the movement looks jumpy. Where did I go
wrong? Should I have used the Easy Setup DV-NTSC?
24p requires you to capture it normal NTSC (29.97)
If you want 24p to be 23.98 then you need to run it through Cinema Tools.
Then place in 23.98 timeline sequence.
24pa (f6) can be captured with advance pulldown removal and editing directly in a 23.98 timeline after capture.
