2 transmitters to Senn G2 ENG kit receiver?
strangways
I've searched, read manuals, asked a few (sales)people, but I'm still not clear on something.
I'm planning on purchasing the Sennheiser 100 Series ENG kit, with the lav, transmitter, receiver, and plug-in XLR transmitter.
I'll only have the one receiver, so I'm only recording to one channel on the camera , but can I (and is it wise to do so) have both the lav transmitter and the XLR transmitter sending audio to my one reciever (and therefore one channel) if I at least balance the output on the transmitters?
Will the receiver even work at all with two units transmitting?
Further to that, or instead of it, can I at some point add a second lav and transmitter, going to that one reciever and one recording channel?
Or will I have to break down and buy a second receiver... and try to come up with some ingenious method of mounting them both to my camera?
Thanks so much.
Oh, wait a second, two more! :cheesy:
Does anyone have experience/reviews on:
1) Sennheiser MD-46 mic as a durable interview mic, wired or with the plug-in transmitter
2) Sennheiser MKE 2-ew Gold lav, as a replacement for the kit lav, to reduce clothing sounds
Okay, I'm done now. Thanks!
mm i have 2 kits, but never tried to actually use 2 transmitters on the same channel.. part of me tells me it wouldnt work, but its not digital so it just might.
One transmitter, one receiver. Two transmitters on same frequency will just give you noise.
MKE-2 is a GREAT lav but will not make a difference in clothing noise. Reducing clothing noise involves placement, reducing the movement of clothing, the type of clothing, and a bit o luck. :)
Instead of the MD-46 I would spend the money on an Electro-Voice 635a or Shure sm58.
Cheers
You can transmit from 2 transmitters to 1 receiver, but it will sound like crap. Don't do it. Or try it out just to see for yourself - but not on a real job. That's why 2 radio stations don't transmit on the same frequency.
It's easy to mount the G2 receivers on the DVX. You can just clip 2 of them on the hand strap.
I use MD-46's and they sound great. The only thing that you have to remember is that they are cardioid, so you have to point them in the general direction of the audio. If you need an omni mic, most ENG guys use Electro Voice RE50. I like the MD-46 better because it has room for a mic flag, a hand and a plug-in transmitter.
Thank you everyone for your input.
So, one transmitter, one receiver. (And the DVX set to Line input as someone said in another thread - makes perfect sense now that you say it - thanks!)
Thanks to wabbit, I don't think the MKE-2 will be that much better (in my particular situation) to warrant the extra cost, so I'll instead put that into getting a lav/transmitter/receiver kit in the future, so I can have two wireless lavs, or one lav and the XLR plug-in going at the same time.
Until that money tree I planted out back starts to grow, I can just rent it.
I'll mount one receiver on the accessory shoe, and clip one on the handstrap. I was just thinking "belt clip" far too rigidly... thanks, Sumfun.
I took a look at the Shure SM58 on their website, and I almost hate to admit it, but I don't like the look of it. Considering this is a mic that will be visible on camera, I don't feel it has the sort of "professional" and modern look that the MD46 has. Same with the Electro-Voice.
I'd hate to pay a premium price for looks, but because prices are pretty similar, are either of the mics that noticeably better than the Sennheiser MD46 in terms of audio quality to make it worthwhile?
This microphone adventure is turning out to be pretty pricey, but now that I truly appreciate what a difference quality audio makes, from recording it, to editing and mixing it in post, it doesn't seem unreasonable to spend (if I add a shotgun and boom pole) on audio 50% of what I spent on the camera.
Actually, considering how versatile it all will be, and how long it will last me, it's starting to look like quite a bargain!
I look forward to spending more time in the Audio forum here. Learning, and hopefully someday, adding my own experience to the mix. Thanks guys.
I'm not sure line input is the best setting. 2 reasons:
1. Most people think that the pre-amp on the dvx is better than the preamp on the G2. So they would rather set the input to mic and use the dvx preamp.
2. If you use the line input, you would have to set the dvx input volume to about the 2 o'clock position (almost maximum). Usually it's better to set the volume near the midpoint in order to avoid distortion.
Keep in mind G2's are defaulted for use with "Input" set, if you choose to use Mic you need to adjust the AF out on the receiver to I think -6dB, it is defaulted for +12dB, check in the manual, but I'm pretty sure they suggest -6 as the ideal.
I always use input and not mic, I've always had nightmare problems setting either of my G2's to mic. Could just be me, I dunno.
I guess what would be best is to run some tests and see what you think sounds better.
Billy
I'll definitely need to run some mic/line tests, then.
There seems to be a lot of confusion surrounding mic/line in general. The manual hardly makes it clear, either. I wish it simply said somewhere that "mic" is a preamp. That pretty much says it all, dontcha think?
Search this forum. There's been some past threads where people gave their recommendations for setting the levels on the G2's.
I used a couple of G2s when I shot some video of a HS football team practicing last November. I had the lav on the head coach and the receiver on my DVX. I had given a handheld mic on the plug-in transmitter to a friend (who knows nothing about audio/video) to hold for an interview we would do after the practice session. It happened to be tuned to the same frq as the lav. The mic had been switched off when I handed it to him, but during my shoot he switched it on at some point. The next thing I know, I'm getting all kinds of hits in my audio and it took a while to determine its source.
Don't do it.
Don't do it.
LOL, had exact same thing happen to me several years back. Was doing a trailer shot (10 crew, 4 cars). My (temporary) boomguy start fiddling with a buttplug I had in my kit, switching it on and off. It was tuned to same frequency as one of the wireless in set vechicle. I stopped our whole caravan for half an hour trying to track down the source of the interference. Tremendously embarassing when I finally figured it out. Figure that little booboo cost the production at least $500. Needless to say, I never worked him again (that was just one of his many boneheaded moves).
Had managed to repress that memory until you told your story Terry...thanks :(
Before you hand out the transmitters set them to different frequencies... then you can have 'em all on and simply switch between them on the receiver. If you use presets established by the G2 it will set up compatible frequencies (no intermodulation)... so running multiple transmitters isn't a problem... then you just switch between each one like using your car stereo. If you leave the receiver flashing on CHANNEL then you can do all this on the fly... that's why I got 3 transmitters for each receiver...
The switching action isn't fast enough to actively mix a natural conversation (there's a 1 second delay) but it's still a GREAT convenience.
Hey matt, when you switch the channel on the receiver, does the transmittor "magically" follow without having to physically do it....or does the person wearing the Transmitor also have to manually retune?
I'm talking about running TWO transmitters simulaneously... both on SEPERATE channels which are just one channel apart... so then if you want transmitter/mic/speaker #1 then you switch your G2 to that... then let's say you want to go to transmitter/mic/speaker #2 (who is at the opposite side of the room)... you just switch to that. Follow me? You still can't run both transmitters as if they were feeding two seperate receivers... because there is a 1 second delay each time you hit the button... but you can switch back and forth with a 1 second delay... which offers the convenience of having two speakers ready to go... both wired with lav... and all you gotta' do is have a 1 second gap between speakers. Sometimes this isn't that big of a deal, but in certain cases it's a HUGE help.
