MattinSTL
Sound Modulator
So does anybody use one of these? The construction is nitrile foam grip, black delrin core, and 3/8" stainless stud. All I need to know is whether or not the outter grip is actually fixed in place with an adhesive? Can you feel any play? I would assume that you could, because with a friction fit there's no reason to complicate construction with glue!
Also, the bottom threaded mount... those threads are formed directly into the black delrin correct? The only metal part of the entire assembly is the 3/8 stud on the top?
Those grips are $35.
I've got several mounts and I don't need one of these things, but since I've been encouraging people to get K-SSM shockmounts for so long I wondered just how many people ended up with one of these since it's actually the best affordable option short of making your own.
