Stymied by Apple Pro Tutorial and my G5
CareyB
This is only my second post. I'm doing the Apple pro tutorial by Diane Waynand, trying to learn FCP while I'm waiting for my HVX to arrive. I've got a dual 2.5 gb G5 w/ 4 gigs of RAM, the big monitor, a LaCie 500 gig external drive and currently I have FCP HD V. 4.5 on the machine awaiting the release of FCP Studio and the arrival of the HVX. The internal is currently set as my scratch drive. I'm a nuggy to pro video, but I have lots of experience with still photography, also I've done a lot of screenwriting.
I'm in chapter two of the tutorial where you're to double click the sequence you've created to open it up in the timeline. No dice. I double click and I get these messages one after the other: 1) codec not found. you may be using a compression type without the corresponding hardward card. Then after ok to that it says: 2) error: out of memory (--such is not possible). Can't go further till I figure this out. I have the thing set up to use DVCPRO HD 1080I60, but it could set it for anything, or nothing. I just want o do the entire tutorial and get on with things. Any assistance would really be appreciated. I've owned the machine and software longer than my right to free support.
I've learned a lot just monitoring this group and hope to contribute something of value as time passes. Your help would sure help.
Carey
¨I have the thing set up to use DVCPRO HD 1080I60¨
try to set it to dv ntsc
Thanks. Tried that and still doing the same thing. Spoke with Apple and they're no help, suggested I seek help through a users group.
If I try to move any sequence file from the browser to the timeline I get this result. I can open a new project which will create a timeline for it and move clips to it but I can't move one from the browser, even a copy, down to the timeline, Just get the codec not found...message and then out of memory in next error dialog window. Really frustrating that I know just enough to paint myself into this corner.
Apppreciate your suggestion.
Carey
Have you tried the usual trouble shooting things like trashing your preferences or repairing permissions?
-A
-A
Thanks for the suggestion. Already tried that and found I could no longer find earlier work I'd done. I think after checking the Apple FCP site that I'll reinstall FCP and hope for the best. I think it's likely that I'll lose earlier work I did on the tutorial but I've lost too many days progress just trying to find a resource for help.
Thanks, I'll keep you informed.
Carey
Found out there was an update available I hadn't gotten and I am able to proceed with my tutorial. Thanks for your advice guys. Hope I can help someone in the future.
All my best, Carey
glad the update fixed but maybe this will shed some light in the future...
took me a while to figure out that when you change your a/v settings, it only applies to new sequences created after the change. your current sequences will remain unchanged unless you go into sequence settings. boggled my mind for the longest.....
