MattinSTL
Sound Modulator
Probably like many of the rest of you... I've got hundreds of feet of Canare Star Quad. We all say it ALL the time.
"What cable should I get?"
"Canare Star Quad"
But a while back I ran several cable posts... and one member got me thinking about WHY we always suggest SQ? This guy said I should really check out a relatively unknown cable product... Musilux.
Well I got some samples and while I was impressed... I wasn't initially blown away. The main reason this member suggested that cable was for flexibility. Musilux is said to have NO memory... but in fact it does have a little... so expecting a spaghetti-noodle soft cable (and still getting one that really IS about twice as soft as Canare Star Quad)... I made up some shorties with my samples and basically forgot about the product.
Then a funny thing happened. I couldn't tell for sure, but it seems like the sound I get is almost better whenever the Musilux is in the audio chain. You can find posts from me making fun of people who think that a cable can change sound or reduce coloration of sound... I've always laughed at people who "listen" to cables!
But this feeling that I was hearing some hard to define difference got me curious. So I started doing research about various levels of cable.
Even within Canare's OWN line of cables there are MUCH more expensive mic cables then the Star Quad! Why? If Star Quad is the "end all" cable then why would Canare sell much higher-end cables for the same purpose? The ONLY way it makes sense is because there MUST be a difference in results!
The more I read about cables the more I realized that even if you want to distill all the snake oil out of it... you will end up with scientific reasons why an audible quality difference is possible between cables!
Before I quote the specs on various cables... I'm wondering how many of you have experience outside of Canare Star Quad? What is it that YOU think makes a cable good? Why did you choose the brand you did?
(In case it's not obvious where I'm going with this... I ended up buying a thousand feet of Musilux)
"Canare Star Quad"
