Hello all, I have recently been experimenting with differing frame rates / shutter speeds to get some faster / slower effects with the DVX100 (no A or B
) but I have found myself stuck with some finer points of the relationship between the two.
I can't seem to wrap my mind around the concept of how one can increase the shutter speed but still keep the frame rate the same. I have always understood shutter speed to effect the light entering the lens and thus hittting the CCD - the higher the shutter speed, the higher exposure required to compensate, and also the less motion blur. Frame rate I understood to be the number of images flashed on the screen per second. Pretty basic understanding...but after looking at the DVX Book and thinking about shutter speed and pairing it with Frame rate my brain started to have trouble...
I guess my question comes to this: If a camera is filming at 24fps, and the shutter speed is set to 1/48, the shutter "eye" is open 24 times a second, and closed 24 times a second which is easily reconcilable with 24 frames per second. For the sake of ease, lets say I shoot at 24fps and set the shutter speed to 1/96, meaning the "eye" is open 48 frames per second. How can the "eye" be open 48 times per second yet still display only 24 discreet images.
My previous experience tells me that setting the shutter speed to higher would cut light down and severely reduce motion blur (and vice versa)...but why would I want to take it into consideration when overcranking or undercranking the camera in any other capacity but to reduce / increase light?
I'm not sure if this is even clear...but any insight would be appreciated!
Thanks!
-John
Thanks!
-John
