You know, honestly I would just re-jam every new setup, but I'm ultra paranoid. But I think you will be very safe with every hour. The drift wasn't severe at 6.5 hours (like 10 frames or so) and at an hour there was no drift. I'll keep testing (you should test too, I was running a TS2-SB at 30ND). I haven't tested other frame rates yet, but will. The TS3 has a new(er) crystal, so if the drift is in the slate, yours will probably be more accurate than mine. (BTW, the best way I found to test was to run video that included both the slate and the screen on the Tascam, brought it into Vegas and bounced frames to check. Some people also use a digital camera, which is probably easier.
Phil
EDIT: I just looked over my notes again (and the actual footage in Vegas) and I was way off (I always do this late at night...I need to start doing my posting in the morning right after my first cup of coffee). The drift started after _6_ hours, not 1.5 hours (not sure where that came from).
Sorry about the confusion. But, in my ultra-paranoid world, I would still re-jam durning each setup (besides, it means that you have control of the slate when equipment is being moved, not an AC, who probably doesn't understand that the slate costs more than he/she is making for the entire shoot. ;-)
Phil
