Slimothy
Thanks.. Very good insight indeed. Did you see my post about the camera stuttering ( a few posts up) Do you think I should bring it somewhere to get it checked out? Thanks again so much everyone for your help. Tim.
khmuse said:The fundamental problem isn't necessarily the AC adapter, it is two connections that have ANYTHING common to the AC mains. Here is what can happen.
If the camera is connected to the computer via its 1394 interface and the camera is connected to a DVD player there is the potential for the camera acting as a conduction path for any leakage currents that any of the other products have. Consider if the DVD player is also connected to a TV. TVs are notoriously cheap in their design. They very often use a concept named double insulated as opposed to real power transformer. The TV connected to the DVD player, connected to the camera, connected to the computer puts the camera's electronics in the path of any event on any of the following devices:
Cable TV (or any of the miles of lines connected to the cable box)
Antenna (and any environmental events)
DVD player, which will likely have a switching power supply in place of a real power transformer (to save manufacturing costs)
Now the only path to a real ground (3 wire mains cord) is through the camera to the computer.
Mythfit, is correct, use batteries whenever possible, but not for the reason he stated, it is to lessen the conduction path by one node (elimination of the AC adapter).
If you want to be safe when you are capturing an analog source (such as the DVD player) capture to tape while running the camera off of a battery. Then disconnect everything from the camera, before connecting the 1394 interface to transfer the contents of the tape to the computer. This will keep only a single mains related connection to the camera at any one time and therefore preventing the camera from becoming a conduction path.
Hope that this very abbreviated explanation is sufficient.
