Phillip-
Was that score from Les Vampires?
EDIT:
Just rewatched and saw the composer. Ludwig... duh.
i can actually imagine philip bloom's voice as i read the review.
Going to recompress tonight and fix the artifacts. Having weird issues at moment...with my computer too!![]()
Philip,
After putting the original 1080p version up on the big screen and with close inspection, the first scene does not look like artifacts, but in fact grain. At least on my 50" DLP, the dirty look is completely stationary, which is contrary to how artifacts would / should behave. The fact that there is grain is not totally surprising as this is, after all, a static adapter. Other adapters experience similar issues with sky when the 35mm lens is stopped down too much. And perhaps this was the case here as well with the G35. But I think it's fair to say that people have a concern about if or when grain shows up on a static adapter.
However, looking at the latest version you posted, I was dissapointed to see that the portion of the scene where the grain was clearly visible is now blacked out. I was hoping to find out that they were artifacts and that, through proper compression, they cleared up. Instead, it is blacked out, further adding to my suspicions that it most likely was grain.
IMHO, covering up the grain in this version doesn't give a true representation of the adapters abilities...good, bad or ugly.
Clearly, the G35 is a remarkable static adapter. But it, just like every other adapter, has limitations. With all due respect, isn't that the purpose of a review...to show the good along with the bad as they show up in your footage?
I could be over reacting as I've been traveling across the country this week and I'm pretty beat. If it comes off sounding harsh, it's not meant to be. Just concerned about the effectiveness of the review - especially for those that didn't see the original version.
Original version........................................................................ Current version
Like Jonathan's banner ad says, Use it, Abuse it, it can take it.
I honestly can't say if what you are seeing is grain or not. I understand you believe it to be. I'm not seeing it on my monitor.
Of course you still handle with care, you wouldn't want to damage the achromat or lens mount. but the body is a nice solid piece of aluminum.
I love the bayonet mount. but, due to the weakness of the camera, you really should have a rod support set-up.
I will be putting up a post with my experience with it in another week or so. I know that doesn't help right now, but I don't have the time right now to get through all the footage I have shot so far. Plus I want to shoot some more first. The first stuff I shot is all handheld, and I was getting use to looking at the upside down image. So alot of it was more to see what did what with the image.
But give Philip a break. I understand his review may not have covered everything you'd like to know about the G35. But he did take the time to share his first couple of hours with the adapter. and offered an example of beautiful footage, what it's capable of.
that's part of what's taking me so long, I'm choosing to show where it's limits are as well.
