Dear friends,
Been having some problem lately ... Founds cracks and crackles on my mic, internal and external (Rode NTG-1). The recorded sound is not very loud, not to the extend of clipping. But in certain frequency or note, it will sound like you squeeze a paper. I believe it's called crackles.. please correct me if I'm wrong.
Is it normal for this to happen ??
My shooting details :
Camera : DVX 102B (Asian PAL Panasonic)
Mic : Rode NTG-1 (CH Right), Internal built-in Mic (CH Left)
ALC : ON
The image above shows NTG-1 on Right Channel, the bottom graph. and there are a lot of crackles. and I believe many of them are not over 0db and some even quite low.
I'm setting the Right Channel to be slightly higher than Left Channel. So left channel, which is the internal mic is fine. However the left channel will be worse .. if I were to set at the same level.
Never really compared with the time when I acquired this mic, but seems to me that there's no such problem before. until very recently . Shooting conditions has been almost the same.
Would like to get some clarifications here....
- Does microphones deteriorates if we were to shoot very loud scenes like loud screamings and firecrackers ?
- Should I shoot at a much lower level ?
Please kindly advise... Previously I did replace a new mic assembly for my DVX102 under Panasonic because I thought it was the mic's problem. Seems like the problem did go away.. but now .. it's back to square one with the same problem .
Please download the audio file to check for me ... :dankk2:
ALC : ON
