Ghostly scan lines in picture
samdrog2000
Hi, first time poster.
I shot a project on 24p and somewhere in the editing process these horrible lines appeared and I can't get rid of them! I'm using Premiere Pro 1.
Here is a frame grab, i upped the contrast to make it pop.
http://3.bp.blogspot.com/_5hmWkmyCm.../VeS0_JIUxA8/s1600-h/ZOMBEAK+LINES-782485.jpg
I've tried interlacing, deinterlacing, deflickering, switching to pal, reversing field dominance, and basically everything else my brain could scrape together.
The lines appeared after the last couple of renderings but I don't recall altering any settings on the export presets.
Any help would be awesome.
Sam
No, unfortunately no 24p presets on PPro 1.
It didn't become noticeable until late in the process while I was polishing and tweaking and such.
Thanks for responding.
Sam
What Project setting did you use?
What effects are applied to the clip?
What Export setting (eg.compression) did you use ?
I'll take a look at the compression and export settings, but the project settings were all default, I used alot filters, mainly gamma, procamp, brightness and contrast. There was a lot of tweaking the picture, but the lines didn't show in preview mode, only after the render.
I'll look at the other settings and post them.
Thanks!
Sam
Project Settings.... "Default" ? If there was no preset it means you used something else for the project. (Could have been anything)
