I would guess many people could afford the $6-$8k for the adapter-relay, but not a set of cine primes or zooms!
http://www.reduser.net/forum/showthread.php?t=13760
If the crop factor is around 50% for SLR lenses (this is what I've read re the Academy Frame, but I'm not sure) then your widest lens ie a Canon FD 15mm will become a 30mm? If this is right that ain't much for your widest lens.
Could you put grips on that Letus set up?
Stunzi is right: it's a 3000
Yup,
Here is the Pro relay, Ultimate, PDW 700, Zeiss Superspeed and full Zacuto B4 rig including hand grip
Yes! That's what I was hoping for. AVC Intra 100?
Here is a screen grab from pdw700/ ultimate/ b4pro relay/ zeiss superspeed 50mm
Philip,
I see a bit of vignetting on the left and right edge of frame, is that optical or post induced?
