Although the U873R was designed as a handheld, the barrel/size is the standard diameter of a pencil mic, so it's small/light and easy to boom with. Plus, it's got a relatively low handling noise.
What?
It's over 6" long and weighs more than twice what the Oktava does
The frequency response rolls off at the low end (I think around 80Hz). But it's still OK for dialogue.
It's switchable.
Not knocking the Oktava. But I feel the U873R is another reasonable option for a budget hypercardioid.
If you can save some $$ then it would be an option. I would like it better for handheld use, it's kind of heavy to boom and I have my doubts about reach.
You can get a good AT shock mount for, I was going to say ~$30, but that was a few years ago but still probably under $50. You will need that with whatever you use. Personally you get what you can justify spending. I think the Oktava has longer legs, ie even if you buy some $$$ mics in the future the Oktava will have it's uses. This mic ,unless you plan on doing a bunch of hand held interviews etc, is a mic you will grow out of rather quickly. But YMMV
Granted. But, people boom shotguns of that size/weight all of the time ...
