xzuberflutz
Hi,
I'm about to embark on a workflow that I've never tried before and was hoping I might be able to benefit from some of the board members' expertise. Here's my situation:
I shot my current film on Super 16mm and am planning to do a telecine transfer of my rushes to HDCAM in the next few days. I'm then going to get the lab to digitize the HDCAM tape for me, so that I can edit in Premiere CS4. I will be using the same files for effects work in After Effects CS4. I'll be working at a 23.976fps frame rate.
My question is: What format does the lab need to digitize to in order for Premiere to be able to work with the files? Can CS4 handle Uncompressed HD files without any special hardware or plugins? (I heard you need a Blackmagic card or Aspect HD to capture Uncompressed HD, but I'll be bypassing that step since the lab will be doing that for me). If it can't, what would be the best codec to use that would result in the least amount of resolution/color space loss?
To complicate matters, the lab is only able to capture into Final Cut Pro, so the resulting files will be *.mov quicktimes. Will that pose any problem for Premiere on a PC?
Finally, I know I could edit using offline files, but I don't want to since I don't have the budget to rent an HDCAM deck, or to pay for the lab to do another recapture. I also want top quality files from the get-go for the After FX work.
Here are my machine's specs:
Desktop PC running Windows XP 32-bit
Intel Dual-Core 2.33Ghz Processor w/3gigs of DDR2 800mhz RAM
1TB external eSATA drive for raw footage
nVidia GForce 7300GT with 256mb DDR2
Thanks so much for any help you can give. HD gives me a headache!
Dave
Dave
