Hi guys, it's been sometime I posted. Here are pictures of my support rails. I have sold quite afew of these already. Here's a clip of it in action http://www.vimeo.com/2894398
These are acrylic tubes. These tubes are hollow with 2mm thickness and is very rigid. They will not flex unless the length is about a meter. You can use your own aluminum tubes as well provided they are the standard 15mm diameter. I have followed the industry standard making the tubes 60mm apart (center of rod to center of rod) so you can take these parts and mix and match with a cavasion rail system as well. You can also add a mattebox to the acrylic rods too. The only problem is that it takes about 4 and 1/2 hours to cnc machine mill to cut out one set of plastic and another 2 hours to drill, tap and assemble the components. If I get enough orders I will upgrade my cnc mill so I can cut the milling time down by 1/2. I'm also considering adding some rubber to the camcorder mount.
