For some reason, whenever I export a 24pA timeline to DVD Pro4, it shows up as 29.97 evey time. I experimented with exporting several formats, had the most success with the dv/DVC Pro-NTSC. I noticed that FCP did not have any setting for 23.98 when using this though, weird..... I verified that the file is indeed using 24pA timeline on FCP, but for whatever reason DVDPro adjusts it back to 30p. What am I missing? I checked all the settings on FCP and DVDPro and made sure everything was correct. I was under the impression that you could use 24p on a DVD, only tape you cannot. Is that not correct? What is the point in filming/editing in 24pa if you cannot copy it onto a DVD?
Also had some issues with the proper compression, it is set at default for the h.224 or whatever, that screws it up because it only reads every other 15 frames or something like that, so some of my footage had jump cuts in it because it was not reading the frames properly. When investigating that, I noticed the 29.97 frame rate issue, so I thought i could correct it by exporting it properly. I tried about 5 different combos with no luck.
Anyone know how to fix this?
