That is correct, as long as u use them with the same dof adapter and if u don't change the zoom setting of ur camcorder. (16mm lens might not cover the whole GG)So you are telling me that if I use a 50mm lens from a set of 16mm lenses, I get the same FOV as I would with a 50mm lens from a 35mm cine set and a 50mm SLR lens?
http://www.panavision.co.nz/main/kbase/reference/tblelenseqvform.asp
note: the focal length of a lens never changes, no matter on what camera you use it. What changes is the FOV.
