indybones
Hi peeps....
Little bit of advice here please.....I have been capturing footage 720PN until recently when I tested/captured some footage with the HVX200 using 1080i 50, and have gone to the item properties of the clips which read as follows
Vide rate 25 fps
Frame Size 1440 X1080
Compressor DVCPRO HD (1440 X 1080)
Field dominance upper (odd)
Now the thing that I don't understand is that I captured the footage at 1080i 25 P (progressive footage not interlaced i footage), so why has it come up with field dominance upper (odd) when it's progressive footage?
And should I be setting my sequence settings to
Frame Size 1440X 1080
Pixel Aspect Ratio HD 1440 X 1080
Field Dominace ???????????
Compressor DVCPRO HD 1080 i50
This field dominance thing doesn't happen when I capture 720PN
Thank you so much for your advice and help
Indy
Vide rate 25 fps
Indy
