Hey guys,
Brand spanken new adapter question here!
I was doing some lighting tests the other night with the RR adapter. I was using a 50mm lens with the Cinescreen 2 ground glass when I noticed just how much of the original image I was losing when I zoomed in on the GG.
As you can see here, this is the image when zoomed in on the image.
But when you zoom out, you can see just how much of the image is actually being projected on to the ground glass. (I also placed a rectangle on the image to show how much I need to zoom in to not get base of the motor in the shot)
Is this normal, or am I cutting off more of the image due to faulty placement of the camera on the setup or any other reason? It seems like the camera is aimed too high (or low, I have the flip adapter on) and is pointed too close to the motor, making me have to zoom in even more. It seems I still have a good amount of image on the left and right I could get if the camera was just pointed away from the motor more.
Any help would be greatly appreciated!
Thanks,
Justin
Thanks,
Justin
