notharrylume
Developing a plan to acquire my first light kit I face a problem I can't resolve.
I want to shoot location interiors using available window light supplemented by hard (mostly Fresnel) and soft sources. Soft sources is easy because I know I can get econmical high CRI flo fixtures balanced to either daylight or tungsten. They are cool and use elctricity ecnomically.
Hard light is my problem. Tungsten Fresnels are economical but they are hot and tax the electrical circuits of locations. Further, they need to be balanced to the color of the window light.
I know that I can by rolls of CTO to cover the windows, but that is not inexpensive, and it involves quite a bit of work. CTO will knock down the intensity of the window light, which is good.
I know I can gel the tungsten fresnels with CTB, but that knocks a stop off the light intensity forcing the use of more wattage creating more heat and potentially circuit blowing electricity.
I know that I can use HMI Fresnels to solve the tungsten Fresnel problems with a daylight balanced source that uses electricity efficiently and genersates less heat, but they are ruinously expensive - costing maybe 10 times what a comparable tungsten fixture does.
What would you do?
What would you do?
