Dennis Wood
DVXuser Sponsor
Edit April 2nd : 15mm and 19mm versions now available
Our earlier customers will know that nearly a year ago, the follow focus project was supposed to have come to fruition...and despite having units in stock, we sold none of them. This patent pending unit represents a complete redesign of the concept using a build quality that will literally last a lifetime. It is our first project that was professionaly engineered entirely in a collaborative 3D CAD environment enabling a complete redesign-to-production cycle of less than 2 months. Rather than just putting a gear and knob on an radio controlled car transmission (as other manufacturers have done in this price range), we've purpose designed every component and manufacture them here in Canada. The highly refined/sealed internal gear set and bearing assembly assures effortless movement under even heavy loads, near zero lash, and a lifetime of maintenance free use in a commercial environment. The entire unit is computer machined from 3 aluminum billets (mount, chassis, focus knob) leaving plastic used only for the dry-erase focus ring and interchangeable .8 film pitch drive gear. A .5 pitch drive gear option is coming as are the whip and speed crank. The focus marking ring is designed for multi-angle viewing, and is both indexed and attached magnetically. Our single rail mount design is rock-solid, incredibly versatile and opens up rail space for other accessories. The unit can be mounted left or right, at any height (including upside-down), with the focussing head angle adjustable to suit your needs. In any configuration, the unit can be used with the drive gear oriented forward or back. Designed to work on any 15mm rails system, expect the 19mm option very shortly for use on the RED and larger cinema cameras. Existing owners will only need to purchase one part to use their unit interchangeably on 15 or 19mm rails. The unit ships with three of our aluminum annodized universal focus rings (with 360 degree unhinhibited rotation) for mounting to any 35mm lens. The current pricing of $890 is introductory. A lifetime warranty will be standard.
The Video University overview of the system will be available for viewing in a few days.
EDIT: Quick clip of the mounting system being loaded up!
