you are forgetting the other two triangles, the shadows and the highlights. used in combination you can pretty much do all those things you listed in curves.
curves isn't all powerful, you can't really lift the shadows without affecting the highlights and vice versa. if you pull on the shadows, the curve will adjust and affect the highlights unless you start adding more points but then you are going to start seeing some posterizing.
and i'm not bagging on curves here, curves are great, i use them interchangeably with levels. in fact i was like you a couple of years ago and didn't even give levels a look at. but they both have their strengths and weaknesses. once you use a 3 color wheel like colorista, you'll never go back to curves or levels for anything but corrections.
