i have a short quicktime movie i edited and put some effects in AE, it was shot at 24pn, but when i render it out it plays choppy....what am i missing?
quality and audio are perfect.
i'm on an intel mac using leopard, the .mov file is only 640x360, looks like the bit rate is at 8 on the composition and the resolution is set to auto
my last mac was almost 2GHZ slower and spit out these files just fine
what do you think it might be?
Bit rate??? Do you mean 'frame rate' of 8 frames per second???
The bit rate I refered to was in the render output options, and with a codec that one can tailor the compression to a given 'play back' bit rate, say 6 Mbits/s for Standard Definition (or nearly so, such as your case of 640x360...), or 20 Mbits/s for HD. This is for 'play back' only, as such low rates would affect quality if this was just an intermediary clip for some future processing. I've had some problems playing back when I use the Animation, no loss, full resolution, (even SD), output on some laptops... there the actual data rate may be up to 100 Mbits's and there for may actually exceed the disk drive's (depending on age and type) maximum data rate. I've not kept up on current disk drives, but still I think the actual max data rate on a drive is somewhere between 100-250 Mbits/s, and that can depend on rotation speeds, or 'raid' arrays, to get higher performance. This particular spec is often buried, and one has to look for the 'sustained' data rate, not some 'instantaneous' or 'disk drive 'cached' sector (very limited...)' rate.
Also, unless that's a typo, a frame rate of 8 frames per/sec is really low, especially if you are using 24p.
If your intent was to produce a 'slow mo' effect, that's not exactly how to do it, and further, enabling frame blending would smooth out some jumpyness.
