I just had the chance to get hold of a Chrosziel Follow Focus and a Redrock Follow Focus, so I thought I’d just do a review on it here.
So here I have a Chrosziel FF & Redrock FF. they are both reviewed as one of the best FF at FreshDV. (Go here if you haven’t seen it, it’s a great video review http://www.freshdv.com/2007/10/freshdv-reviews-five-follow-focus-systems.html)
First is the Chrosziel FF (206-01S) priced at around $1500. And it is very expensive. The great thing about this FF is that it’s well build and it’s very light weight. The FF has no play (maybe 1mm) and it has a really nice finish touch on the rubber grips.(the best) The indicator moves and locks down at any position too. This FF is just perfect and there is really nothing I dislike. Well I guess after pricing this for $1500, this should all be expected.
Next is the Redrock FF priced at around $650 (w/ gears) The great thing about this FF is that it’s build like a tank. I really like the build quality on it and I know why everyone has the Redrock FF now. It’s priced very well and it’s build so solid.
However, there are a few minor things I dislike. For example the weight is one. It’s build rock solid so it’s kind of heavy. It’s not as heavy as it become a problem but let me just say this FF is a LITTLE big and a LITTLE heavy. (see picture of how big it is compared to the Chrosziel)
Especially the hand wheel is the heaviest part. so all the weight is on the handle which make it feel even heavier when it’s on the rods.
Also I would like to see a more solid piece of indicator on This FF. Because this indicator is just a piece of metal that looks like it can chip and break easily, (plus the indicator doesn’t move in any direction)
The Redrock FF has about 1mm of play but I would say the gearbox has no play at all. The 1mm of play actually comes from the gear that is attached to the FF. the pitch gear is attached to the FF with a single connecting screw and no matter how tight I tighten the screw the gear is 1mm loose.
One thing I found funny about the Redrock FF is that it works great with whips. For some reason when you turn the Redrock FF with the whips it’s much smoother and easier to make a full turn. I have no idea why this happens but I think it is because the whips have a smaller hand grip so it’s easier to make a full turn and it becomes smoother somehow???
One more thing I should mention about the Redrock FF is that it has a big gap between the gears and gearbox/handle.
It isn’t really a problem if your using it with your 35mm adapter because you will have a lot of space to work with but if want to use it on your camera, you might want to rethink about it. Because the Redrock FF can not change there gear position.
(Chrosziel FF can change the position without any problem)
So if you want to use it on your camera you will have to reverse the FF to the other side so it will reach the lens. (but who really uses a FF for their camera?)
I would say the Chrosziel and Redrock FF are both great FF.
The Redrock is heavy and big but I would get the Redrock if I had $1500 to spend. I just think the Chrosziel is just too expensive so I would be happy to keep the extra $800 in my pocket.
