yesDo I need to use compressor?
If so, how would I compress it to fit?
In FCP, select your sequence, with In/Out points set, then goto File>Export > Using Compressor.
In compressor, goto your settings window. Drop down Apple>DVD>DVD Best quality 90 minutes. Drag the "DVD Best quality 90 minutes" folder up to where it says "Drag your settings here".]
Thought i would ask a question. I have picked my settings and destinations, Compressor tells me that everything is complete And successful, but when I go to watch the video, I have no sound. I applied the sound setting that is in the same folder and the encode I choose. Is there anything I could be doing wrong or missing a step? Thanks
Where are you watching it? What program? Keep in mind you will get two separate files for audio and video, you will need to drop them into DVDSP to watch and listen to them concurrently.
