Choice of camera for stop-motion miniature
ProfessorU
I am having a dilemma choosing a format and camera for my stop-motion miniature senior project. I had an idea in mind, but every time I explain it to someone (most notably the professor who will be grading the project), they tell me I'm way off-base and everyone suggests a different way to do it. I'm going to explain it here, and maybe I'll get some answers that make a little more sense to me.
The final look is going to be black and white, sort of a mock-german-expressionist vibe (think Tim Burton's Vincent crossed with Wallace and Grommit). We would like to have a 16:9 finished product however. I'd love to be able to do a 35mm print if we submit to festivals, and I might be able to afford it since the final length will be under two minutes.
My professor suggested a CP-16 regular 16mm camera with single frame advance, shot 16:9 safe.
The guy who runs the equipment checkout suggested a MiniDV camera with a 1/3" chip and single frame capability.
One of the guys on my team suggested a high-end dSLR.
I think we should use a point-and-shoot camera like the Canon PowerShot S5 IS.
I think the smaller sensor size on the point and shoot is an advantage, because our subjects are 1/12th scale. We should be able to get DOF to approximate a scaled-down 35mm camera without having to stop down to ridiculous levels and flood the set with light (or, to put it another way, since all our shots will be macro, we'd like to keep the set only slightly fuzzy). We can make digital tweaks to the high resolution image to make it look like tri-x reversal or double-x negative in post.
Does a smaller sensor size make sense here, or am I shooting myself in the foot? And is working on film as big a pain in the ass as I think it will be? And won't most of the advantages of the dSLR (low noise, sensitivity) be relatively worthless in a controlled lighting environment?
going with a DSLR would be your best bet for rez and lenses. They did that in the last Wallace and Grommit. You can shoot as high a rez as possible and be able to reframe, letter box, zoom, etc. to your hearts content and still have some image left over to work with.
DSLR.
Corpse Bride used them for parts of the film and when MY Name is Earl shot that episode with stop motion, they used it to.
Either shoot 35mm film or DSLR.
DSLR will cost you much less.
I don't think smaller chip cameras with deeper depth of field will help you do anything. Just add more light and close down. I think you are underestimating how much light you have. Lighting those small sets for stop motion is usually very bright because the light can be very close. Point and click simply lacks manual control you need, and if you want to release in 35mm, 1/3" mini DV is not enough.
dSLR all the way. You can control your exposure with the shutter speed, giving you freedom with your aperture and DOF, as well as the aforementioned benefits (total control, that is). Plus you have more color information to work with than MiniDV if you shoot in RAW.
