thekreative
Hey Jon, Just wondering if people can visit for a demo and if there is a EOS mount in the works (C/Y would be even better)? Looking good!
Good to hear youre shipping Jonathan. Long time coming....
Yes, I currently own the redrockmicroEric,
Have you worked with 35mm adapters before?
Jon, what is the widest lens you can use with the G35?
or what was the widest lens you used on "How Low?"
some shots were dark at the edges but are they showing any vignetting?
Will the bayonet mount for the HVX200 fit the HPX170? I know the thread size has changed from 82mm to 72mm, but I am unsure of whether accessories for the bayonet will be compatible.
Well, I thought I remember jan telling someone on the boards that they need not worry about the bayonet mounted wide angle lens they currently own for the dvx100, because it should be compatible with the HPX170.
I'll see if I can find the post.
EDIT: K, it wasn't Jan but Barry who confirmed
http://www.dvxuser.com/V6/showpost.php?p=1367228&postcount=9
Jonathan,
this might have been answered before, but can you stop down to say f4-f8 and not see static grain in blue skys and clouds?
and do you know the roll-off point for the level of brightness effected by opening the taking lens's aperture?
for example:
when opening the lens from f8 to f5.6 the brightness might increase apox 1 stop. but when opening the the lens from f2 to f1.4 the brightness might only increase 1/10th a stop.
reportedly the roll-off for the brevisCF1 is around f4 (from memory)
and my SGpro's roll-off is at f2.
have you done tests for this stuff?
thanks
Jonathan,
I'm deeply happy to check out you're alive and kicking -- as well, the best 35mm adapter ever!
All my best as usual,
Emanuel![]()
I will be uploading HD stop down footage tomorrow with F-stops indicated as that is the best way to show how the G35 deal with stopping down. As for the roll off, the reason those other units are not affected when you open the lens all the way is because they have a narrow scattering angle. This is done to gain light by using a shaped diffuser. The downsides to this is that the light does not get scattered to the edge of the clear aperture of your lens resulting in a "blurry" bokeh or a hot spot in in the middle your blur circles. The G35 increases it's light gain in accordance to the lens. So there is no roll-off.
