Can Scanner
I think the headphone jack on my HVX200 is starting to go. Sometimes it works fine, and then it cuts out completely. You can get it working fine again if you jiggle the cable a bit. (I tested with a different set of headphones- same problem.)
There are some small screws on the side, and it looks like I might be able to easily replace the jack (with a part from Radioshack maybe?).
Anyone had any experience with this?
Thanks in advance!
Thanks in advance!
