I'm using a DVX, but I don't think these questions are DVX-specific. I have the manual handy, but couldn't find the answers to my questions.
1. Are back-focus settings permanent? In other words, can I record the settings for a fine-tuned back focus and simply set the camera according to those settings whenever I use the camera and M2 adapter next?
2. The manual said to turn Auto-Iris and Auto-Focus off, but does that also mean I should manually set the Iris to "OPEN"? Is there a situation in which I would close the iris of the DVX -- if it should be set to open by default?
3. The horizontal and vertical alignment looks correct, but I'm not getting the crisp images I want. There seems to be a lot of noise in the picture -- which points to a focusing problem and an exposure problem. Which I guess leads me to: what zoom/focus settings are you guys using for back-focusing the M2? I think I should have approximately the same back-focus settings as everyone else...
With the M2 motor off, I still don't see visible grain -- which the manual says I should focus on. I'm using an iKan v8000HD monitor. If I turned up the gain on the DVX, would that help and be accurate?
Hopefully this all makes sense...
Thanks,
Sean
Thanks,
Sean
