How bad is fungus in a lens?
semila58
Even if a lens is professionally cleaned and de-fungied, isn't it still likely to grow back? And what kind of problems does fungus cause in a lens?
Peace,
S-
Toss it. Unless something's changed in the last decade, fungus is pretty much a one-way street to lens destruction. The fungus will grow and etch the lens surface.
fungus at its early stages can be removed. our lens tech uses toxic solvent type cleaning fluid that kills these organism. Its not advisable to leave them on while they're still small and negligible since they are "feeding" on something, in this case the lens coating. in its early stages a good lens tech can remove them while its damage is still in the area of the lens where it doesn't affect its performance.
Sometimes the fungus hasn't eaten off the entire layer of lens coating so its removal still helps.
Humidity is usually the culprit in our tropical country.
keep it stored in dry clean environment to lessen chances of it coming back after its cleaned.
...since they are "feeding" on something, in this case the lens coating.
They certainly sound like a hearty creature if they're eating the lens coating. I can see how they would be difficult to control after a certain point.
Dont toss it. if fungus is caught in the early stages, when its still on the surface of the inner element, it can easily be serviced and cleaned. I had an L series Canon lens that had very slight fungus on it, had it serviced for about 100 dollars and saved myself a lens that currently fetches $800 bucks.
Fortunately there wasn't a lens to toss on my end- there was one on ebay that was described as having "one small fungus spot", which could really mean anything. Either way, I went with a different lens. Thanks everyone for your responses.
Peace,
S-
