Thanks for looking.
If someone is willing to explain this to me fantastic! If not, what I'm really looking for is for someone to point me in the direction of getting to the bottom of this! A website, a company, a phone number, an email, anything!
Really quick - I shoot most of my projects on the HVX200 (720p24pn). Of course I use FCP and the other apple apps listed above. My question is why is when I check my burned DVDs on any TV & computer - It just doesn't look good!
I have researched this like crazy! I've changed the GOP & Quality menus. I've done all the compressor presets along with some custom ones. I've tried out putting different formats from FCP. All this experimentation isn't empty thought, I have been reading articles from all sorts of places and then trying what they suggest.
Is compressor & DVDSP really capable of producing high quality SD DVDs? How do I produce them if so?!
My work flow -
FCP (720p24pn -> export Quicktime not self contained)
Compressor (I either use Highest quality 90 minute preset or custom -> my bit rate is AVG 6.2 highest 7.2 -> TWO PASS -> GOP IBP w/ 13 SIZE) Here is the summary
Description: No description
File Extension: m2v
Estimated file size: 160.94 MB
Type: MPEG-2 video elementary stream
Usage:SD DVD
Video Encoder
Format: M2V
Width: 720
Height: 480
Pixel aspect ratio: NTSC CCIR 601/DV (16:9)
Crop: None
Padding: None
Frame rate: 23.976
Frame Controls Automatically selected:
Retiming: (Fast) Nearest Frame
Resize Filter: Linear Filter
Deinterlace Filter: Fast (Line Averaging)
Adaptive Details: On
Antialias: 0
Detail Level: 0
Field Output: Same as Source
Start timecode from source
Aspect ratio: 16:9
Field dominance: Automatic:
Selected Progressive
Average data rate: 6.2 (Mbps)
2 Pass VBR enabled
Maximum data rate: 7.5 (Mbps)
High quality
Best motion estimation
Closed GOP Size: 13, Structure: IBP
DVD Studio Pro meta-data enabled
I Then bring to DVDsp burn a VIDEO_TS then burn at a slower burn speed using TOAST.
Thanks!
My work flow -
File Extension: m2v
Usage:SD DVD
Video Encoder
Format: M2V
Width: 720
Height: 480
Crop: None
Padding: None
Frame rate: 23.976
Antialias: 0
Detail Level: 0
Aspect ratio: 16:9
2 Pass VBR enabled
High quality
Thanks!
