David W. Richardson
Chapelgrove Films
What you describe from the screen print make little sense. When I printscreen, I get perfectly clear images of my screen. The "72dpi" means nothing unless you are printing something. it has nothing to do with the resolution and clarity of the image onscreen. "72dpi" when embedded in an image is only a metadata reference to what size that image will natively print at. Also, the "72dpi" screen resolution is now a fallacy and dates back to the original Macs. I have a 22" CRT display set to 2560x1600 - that equates to approximately 134dpi.
So set that aside. Here is a screencap of my laptop as I see it right now. It is just as crystal clear as the screen itself. Your problem has nothing to do with "72dpi" and the is nothing inherently wrong with screencaps. There must be a problem with what you are doing with it. For mine, I simple hit screencap which copied the screen to the clipboard, opened Photoshop, hit CTRL-N to create a new doc, hit CTRL-V to paste the screencap, then saved as a Lev10 JPEG. You can, of course, save as a PSD and import that straight into Premiere.
My laptop screen resolution is relatively low - max. 1280x800 - but that is still more than enough for SD or 720 HD. I would screencap from my desktop if I needed higher res.
Yes, your cap looks fine -- on the computer screen. How it looks pulled into a video, burned to a DVD, and played on a TV screen is what matters, though.
My screen caps look just fine on my computer screen. It's trying to get them to look good in my movies that's causing problems.
