your performances will probably be better, as well, since you only have to pay attention to one of your actors at a time.).
The BIG problem with the two camera shoot described above is that your actors are both talking at the same time
The audio tracks will not sound different if the actors are speaking to one another at a normal conversational distance. The actual microphone placement should remain in the same position but aimed at the "on-camera-actor" or if possible between both of them equally, this will ensure acoustic continuity. Give your sound man [wearing headphones] the authority to hold shooting until back ground noise, trucks, airplanes, dogs, lawn mowers... are out of the way. You'll have clean tracks to edit
Single camera is a great method. To stop actors from overlapping one another, if they happen to do this, you can try and have them space their lines apart so there's silence between their dialogue. So one would speak, space, and then the other will speak, space, etc... While it can be more difficult for the actors, because the timing delivery is weird, it allows the editor to time the interchange and keeps the dialogue clean. The down side is that it demands that cuts are made, and sometimes you don't want to cut just there.
