An alternative is making your own. Im doing it because:
1. 1440x234 isnt good enough, 800x600 is "nah nah" but not 100% and higher res ones cost shi*loads of money
2. I like to build stuff.
If you willing to build a case and a little extras for the panel-kit you will have kit for around $400 with a 7.2 " 1280x768 panel. Dont know which connections you need, but this alternative only features hdmi, vga and component. The rest of the money is up to you, its all in the design of case and so on.
http://www.mediahump.com/gallery/2778/
Why do you need 5v? =)
It only use 12v for the board and then 24v for the backlight? OR its just the board for another panel that need 5v?
If the pictured MST board is from Pixelworks it will require +5 and +12V and it has it's own power supply circuit for backlight that connects to the main MST board and to the backlight. This Pixelworks board btw can be connected to a additional panel that will give you all the other imaginable AV inputs inc TV antenna but it doubles the size.
T
