When I need to send big files, I zip them up and use a site called yousendit.com. You have to subscribe, but it's pretty reasonable and you can send huge files as needed. The folks at the other end just download it from a link in an email.
You can also set up a drop box so people can send you huge files too, without having to subscribe.
Phil
...You're also far more likely to have an unzipper on the other end than something that supports flac. ...
Compressing wav files with .zip usually takes as much space as flac, since both are lossless. You're also far more likely to have an unzipper on the other end than something that supports flac. I don't mean disrespect to flac... I'm a supporter, but in this case, there's no reason not to use zipped wavs.
Or, if it's for the director and not the final version, a high quality VBR MP3 is probably the way to go.
