I tried the Sachtler DV 6 SB head. I did a rather fast pan and when I finished the pan I let go of the handle and the head swung slightly back, because of the fluid I guess (using 3, 4 or 5 fluid pan setting).
Is this normal?
The problem is: when I use the 2 or 1 pan fluid setting, the pan can´t be controlled as well, I feel the panning speed is not as steady as panning with a higher setting.
I cant remember having had that effect on the bigger sachtler heads with heavier cameras. Is this only happening with the DV6? Should I better get a DV8, or does it also swing back?
The 503 Manfrotto head doesn´t have the good Sachtler fluid feeling panning, but at least when I finish the pan it doesn´t swing back.
Also: I intend to put the DV 6SB on a Manfrotto 525 tripod. Is that a good idea?
Is this normal?
