Avenger007
I've had to take power tools to a couple of adapters before and one of our early brevis units seemed to benefit. I gutted the main housing and used a dremel with a very soft bit to smooth unfinished bits out and then took a super high grit disk to try and roughen up the inside. I used some high grit paper and smoothed things out to finish with a flat matte/non reflective coating courtesy of a local car guy that does our tuning for the company "show" car
. We finished by sealing the ends with a plastic permanent adhesive on the glass after blowing out the barrel with shop air. Seemed to help but elements could not be swapped. The battery/motor and everything was hot/super glued in a similar fashion to factory setup. I sold it a few months ago for a newer unit with the micro collimation and flip.
I wouldn't recommend this for the common user but if you are handy, don't always be afraid to customize to your liking. I've drilled quite a few lens mounts while on set just to improve fitment. I think cinevate has improved on the unit since then. I have yet to have a problem with my new Brevis'
