11) Budget for a quadrupling of you lighting package.
11 (a) Can you say a 1k just became your 650.
Looks like a good setup, just seems expensive.I'm looking at the M2 Adapter and thier Zeiss lens (50mm, 28mm) Is this a good setup?
http://shopping.netsuite.com/s.nl;j...mTe34Pa38Ta3aKc3r0?c=472981&sc=2&category=379
How tight does the adapter fit against the HVX200? I already have the 18" rods, matt box etc coming in.
TO ANYONE - If you had two Hvx200a set up (same in scene file, color etc...) but one of the Hvx200a has an adapter with lens and both where set side by side and you were filming a scene (med shot) and when you got back to the editing room and you look at both scenes on the monitor side by side - how much better would the Hvx200a with the adapter/lens look compare to the one without? Is there enough DOF and quality to make it worth investing?
