Alright kiddies. With all of the adapter manufacturers popping out flip units we've all discovered that you can now zoom in further on the ground glass for a "pre-cropped" image. Consider that even at Academy frame you have the option of zooming in even further to turn your 50mm into an 85mm or so. And of course, zoom it out to "mimic" a wider lens. In truth you're not really mimicking, but doing the crop in camera which is much better than post.
Here's what I've calculated, roughly so, with my HVX200A and Ultimate:
A 35mm Lens @ 55.0mm is roughly equivalent to a 50mm Lens @ 25.0mm, perhaps a 60mm. That means you've turned your 35mm lens into a zoom lens that goes from 35-60. That's not an incredible range, but still, you've created a pseudo zoom lens from one lens, making it a 35-60mm. The trade-off is that the HVX lens, zooming in, becomes slower.
So if that same 35mm Lens is rated F1.4, then it's now something like an F1.4~3.4.
Great. Now the question is which scenario do you choose?
A) 35/1.4 Fixed Focal/Prime to enact as a 35-60mm Zoom lens in conjunction with your cameras widest frame to the longest or...
B) 35-70/2.8~3.4 Zoom lens?
Factors to Consider--
1. Fixed Focal Length may be sharper across the field than its equal in a zoom factor.
2. A Fast Fixed Focal Length may cost more or as much as a slower Zoom lens. In most cases a faster zoom lens will cost more than a fast prime of equal caliber.
3. The overall performance of the lens itself.
