atlfilmguy
I have used the M2 with the HVX200 for about 1.75 years. I am pretty used to it by now and am fairly good at setting it up.
Over the last year or so I have gotten the back focus good enough to limit edge to edge issues but it was still not good enough for me. So I was stoked when the micro X came out. Not because of the flip function of the micro X but because of the improved edge to edge sharpness.
I got it and set it up per the redrock tutorial. And it was MUCH better on edge to edge. It seemed as though it had a larger DOF to play with on the ground glass or something. BUT it did have a new problem. Vignetting.
My old settings were 76 zoom, and 15 focus. Now with the microX it is 91 zoom and 84 focus. I have looked and found that it is within normal range others are getting.
BUT no matter what my zoom is the light falls off with some pretty bad vignetting. I have looked at older footage before the MicroX and it had nowhere near the vignetting.
I wonder if it is the new 55mm Acromat with the 88 stepdown ring? But I can see the vignette change slightly with zoom and when I zoom all the way out I can see the light fall off area on the GG.
I tried to fix it.
I took the back off of the M2 box and took off the cinescreen and moved the GG up a bit (about 2mm) by raising the motor. That seemed to help some just by eye. Then when I put the cinescreen back on I figured I would move it a bit closer to the 35mm lens mount. The vignetting seems better, it is still there and is still worse than before the microX.
I could go back to the way it was before, but I want the microX to work.
Any ideas?
I tried to fix it.
Any ideas?
