does anyone know how to adjust back focus on the new nikon mount? i've got the screws out but i'm not sure what to do from here. i must be an imbecile...
Dan,
Do you HAVE TO adjust the backfocus? (Will the NEW mount work fine when you first get it) ...With the old mount i currently have i've just attached the prime lens and shot.
Regards,
Ben
Hi Ben:
If you are shooting with a prime, issues with the back focus not adjusted will be that the lens may not focus to infinity and if you are using your lenses focus markings, they will not match. In other words, you may use a tape measure to measure off 10' and set your lens to 10' and you may be still out of focus.
If you are using a zoom lens, when you zoom into the farthest zoom length to set focus, then zoom back out, your lens will go out of focus.
All of these issues seem like a big deal to me but depending on your skills, eye, tolerance for slightly out of focus footage, may not be as big of an issue to you.
Dan
Hi Dan,
I've never measured focus before ...with a tape or markings. I just attached the lens and started shooting. The only issues i've had have been with edge softness. Does this mean the new mount will be different out of the box to the one i currently have?
Regards,
Ben
