HELP on how to make 24p 1080i material play progressive PPro v. 3.0
Hello:
After a problem with CS3 I had to system recover my PC and reinstall all Premiere and After.
I got myself a those programs with version 3.0...I upgraded to version 3.2 on premiere to handle MXF files natively and with its normal 2:3:3:2 pulldown for 1080i material.
My question is...now that I reinstalled all... the patch to make it 3.2 on Premiere made a glitch so I dont want to use it (instead use my version 3.0 with RAYLIGHT plug-in) but I see some INTERLACING on my 1080i footage which was handled to 23.976 with version 3.2 but not with version 3.0.
Is there a way to make Premiere 3.0 handle 24p 1080i material like 1080p ?
Id appreciate some feedback on that as I dont want to use the patch to make it 3.2.
By the way...I tried to interpret footage and make it run as 23.976 but still...doesnt work...I see interlacing on my 23.976 timeline.
Thanks in advance to all who come with help.
If you shot the material in 1080i/24p this is 1080p its just wrapped in a interlaced codec, and if you use the prem preset DVCPROHD 1080i 24p
General
Editing mode: P2 1080i/1080p 60Hz DVCPROHD
Timebase: 23.976 fps
Video Settings
Frame size: 1280h 1080v (1.500)
Frame rate: 23.976 frames/second
Pixel Aspect Ratio: DVCPRO HD (1.5)
Fields: No Fields (Progressive Scan)
Audio Settings
Sample rate: 48000 samples/second
Capture Format
HDV Capture
Video Rendering
Maximum Bit Depth: Off
Preview File Format: DVCPro100 1080i 60Hz
Compressor: DVCPro100 1080i 60Hz
Color depth: Millions+ of colors
Default Sequence
Total video tracks: 3
Master track type: Stereo
Mono tracks: 4
Stereo tracks: 0
5.1 tracks: 0
Submix mono tracks: 0
Submix stereo tracks: 0
Submix 5.1 tracks: 0
Hi...and thanks for writing back.
I tried to find those settings but version PPro 3.0 doesnt seems to have those.
Like I said...if i upgrade it with the patch to make it 3.2 and read MXF files natively (and im sure give me more DVCPRO presets) my Premiere crashes...dont know why.
Somehow, when it was wroking, those presets gave my video the progressive handlings it needs to do the " interlace unwrapping" you are telling me about.
Do you happen to know how to do it in version 3.0? I tried ur settings (or close ones) but still...interlace 1080 video.
Do you have other ideas please?
Do you know if presets or settings can be copied from one user to another like " plug-ins" from Photoshop for example?
Maybe that would make it work in 3.0
Sorry for my many questions...
Thank you Phantom video.
Photoshop wont contain these codecs but AE8.0.2 will BUT if your install went ok then those codecs WILL be there, the minuim version for native MXF support in prem is 3.1, 3.0 will not and cant not support it (Raylight could) but for the now you dont need it, a clean install should fix it, and yes you need a 3.1, 3.1.1 or 3.2 patch from Adobe.com,
As for the crashing, try 3.1 first then 3.1.1 its wierd 3.2 made my prem alot solider
I cant install any patch or it will crash as I noticed...thats why I think Id need a way to make those presets work in 3.0. I already use Raylight to read the MXF files...I'm just trying to get Premiere get rid of the interlace in some way...not even "Interpret footage" works...
Yes...3.2 was solid...I just don't know why it doesn't work now in my PC.
