We have a huge stack (300 or so) of mini DV tapes shot on either the DVX100 or Canon XL2, most were shot 24AP but we do know some of them may have been 24p by accident.
I'm dealing with a problem that I've never encountered before, and it has several parts:
First off, when we digitize, we generally do "capture now" instead of logging because we know what we need and it's faster for getting through the amount of tapes we have. But FCP seems to be very tempremental in "removing advanced pulldown" as this message often doesn't appear and we have to keep re-opening the log and capture window, or changing back and forth the capture settings or just restarting FCP to get it to co-operate. At times, I have resorted to just capturing without seeing the "removing advanced pulldown" to save time, and deal with the problem later. Incidentally, everything we are digitizing is all offline, so its just for offline cutting.
We have two G5 systems. One has FCP 6 on it, the other has a version of FCP 5 (only because we just set it up and haven't upgraded it yet). We have been digitizing on both because we aren't cutting anything yet, but this shouldn't make a difference.
I have encountered some clips which have massive sound sync issues (and about 30 of black at the end). These clips ONLY have the issues when played in FCP in the viewer (or canvas). If played in quicktime they play fine. AND even weirder - if played on FCP 5 system, in the viewer they play fine.
The item properties show that these clips are exactly the same as all the rest except that they are 29.97. I checked thoroughly through all the FCP settings, user preferences, sequences presets EVERYTHING, and could not find a difference between the two systems except for the fact that one is a newer version of FCP. So what is the problem here.
Again the 29.97 clips play fine in quicktime, or in FCP 5, but in FCP 6 they have sound sync issues in the viewer or canvas. Its not a sequence issue because we aren't even bringing them into the timeline.
I've tried making copies of the clips and "remove advanced pulldown" manually with tools, but it says there is a "cadence" issue. And this still doesn't explain how they work fine in the older FCP.
This is all an offline edit, so as long as we can find a way to solve the sound synch issues without destroying time code, then we don't need to worry about quality.
Sorry for the long winded-ness, hope someone out there can help. I'm stumped.
D
D
