I have encountered the problem of different Nikon lenses have different size. For example a 24mm up to 50mm f2.8 Nikon lenses have a 52mm to 54mm thread and then the 180mm f2.8 is 77mm thread. Not to mention the fact that the lens barrel also moves back and forth or longer and shorter when focusing. How does one compensate for these types of problems when using these type of still image lenses with matte box? I have seen some matte box have foam type lens adapter or a cloth like that goes from the matte box to the lens. However, I was hoping if there is a way or a lens hood similar to these that I can use on many of the Nikon lenses (24mm, 28mm, 50mm, 85mm, 135mm, 180mm, and 200mm) that can adapt from, let's say, 52mm thread to 77mm and allows the lens barrel to get shorter/longer and turns as it is being focused. If this is not possible, how does one use a Nikon lens with a matte box?
