Cool Lights
DVXuser Sponsor
Pain is right. I hate all this waiting but luckily I usually have several projects running at once and there will be inevitable delays on each of them for lots of reasons mostly relating to some aspect not being right yet. I am including a picture of what I have now. This is the panel with 480 LEDs (24 x 20) and the companion dimmer/driver circuit board. It measures 8 3/4 x 9 3/4.
Actually we discovered they used 10,000K LEDs contrary to my directions! My RED camera (which the auto white balance is very accurate at sensing color temperature) shows exactly 10000K color temp with no other lights on but this one. I do like the actual LEDs that they used though which are known as "superflux LEDs". Very good on power usage and heat output. This panel draws 25w at 12v. I see no CRI issues actually but the color temperature is obviously a problem when being used with other lighting. Pictures I took showed no green fringing like I had with my first panel (from last fall which was actually right on 5600K but the CRI was terrible of the LEDs). Dimmer works fine. I think we'd mount this back to back in the fixture case. Need to find a good place to put the dimmer knob so its not protruding in an awkward place though. I think dimmer sticking out of the back is less desirable than dimmer out of one of the sides.
A final picture showing the panel lit. The LEDs are 30 degree and the beam is fairly round and whiter/blue looking than normal daylight when being shown on the wall next to our 5600K tubes.
I will probably go ahead and continue to use this kind of LED which is a higher quality kind but just locate the lower 5600K type LEDs.
