Chris Klidonas
I have a few questions about greenscreen.
first is it best to capture in 24f, 30P or 60i? will it matter much to the ease and quality of the greenscreen?
Next lets say I have the greenscreen big enough to surround the subject but not wide enough to extend to the extreme sides of the frame. What is the best way to greenscreen the subject and also get rid of both sides of the frame which are not green but not needed.
In other words, I have the shot framed with enough greenscreen around the subject to give say a square frame of subject and all green surround, but not enough width to get all green, but since its all got to go anyway I assume there is a way to mask off the sides regardless of color and then drop out the green around the subject in addition? I hope that is making sense.
And as for the shooting would a frame rate of 1/24 or 1/48 in 24 or 1/30th or 1/60th in 30P be better? Also in 60i I would use 1/60th so this is semi dependent on which is the best frame rate to use.
Another fast one that may be vegas dependent, if I am shooting 24f in a canon hv20, hg10 and now hf10 it needs a pulldown what does that mean and if I do not do it and edit to a 24p movie after the green screen is that a big problem or not one that will effect the actual greenscreen dropout effect?
Thanks for any help.
