I currently have a 2007 Mac Pro 8-Core 3.0Ghz with 9GB RAM. It has a Radeon X1900 XT graphics card running two Apple 30" Cinema Displays. I also have a Highpoint Tech eSATA RAID controller. I recently moved my old plasma to the edit suite with the intention of using it as a monitor after I calibrate it for color correction. I know this isn't a broadcast quality plasma, but it's pretty good and once I calibrate it, it will be good enough until I upgrade that too. Anyways, I'm thinking I shouldn't add another Radeon X1900 XT card because it will eat up all my remaining slots because it's so big. I expect to do more editing work in the near future and may need a capture card. So I think just getting a capture card and monitoring out of that to the plasma would be the best choice. I've been researching the AJA and Blackmagic options and am now thoroughly confused about what I should get.
Mainly, I want to be able to output to the plasma via HDMI(DVI) or component. Looking at the literature and the specs on these cards it seems they don't support all the resolutions and frame rates I work with right now, which is mostly 1080/24pA and 720/24pN from an HVX200. The AJA Kona 3 and Blackmagic Decklink appear to support 1080/24pA (1080PsF 23.98 and 1080P 24?), but neither show support for 720/24pN. The Intensity Pro seemed like it would be perfect, but it doesn't even support 1080PsF 23.98 or 1080P 24. I also looked at the Motu V3HD, AJA Io HD, and Blackmagic Multibridge Pro. Those also support 1080PsF 23.98 and 1080P 24, but not 720/24pN. The V3HD and Io HD are also much more expensive than the card options.
If I'm working with a 720/24pN project (as well as 1080/24pA) I want to be able to monitor out to the plasma (as well as work with the projects on my 30" displays) without having to render all of my P2 clips or recapture/convert all of my P2 clips.
I mainly work with Final Cut Pro 6 and have Magic Bullet Looks and Colorista installed. I also use Motion, Color, and Shake. I'll also be delving into After Effects CS3 a little more.
Audio doesn't really matter to (unless capturing through the capture card) as I have an M-Audio Firewire 410 to handle my current audio needs, which includes multichannel surround sound mixing. None of these capture cards can handle that.
What would be the best option for me? Is there something I haven't even looked at? Thanks for the help.
