I had that same problem, only worst! The fix is a "macro lens".You need to make the focus screen appear larger to the camera.This will eliminate the vignetting.This is my vignetting problem before I added the macro lens: http://www.youtube.com/watch?v=7nJNCSPyFv0. Then I installed a macro lens; http://www.youtube.com/watch?v=yNVbB-AkIlA. Hope this helps.
So if I already have an achromat installed and Im seeing some hotspotting, should I try to find a condenser to also stick on there? Or is there another way to fix that?
