filmguy123
I think the topic says it all. I usually shoot 30p as it looks much better than 60i and works better for dynamic shots, without strobing. But I wonder how much of the filmic look I miss out on by doing this?
24pA is meant to be cut on a 24p timeline. 24p(normal) is meant to be cut on a 60i timeline.If so, what IS the advantage of 24PA opposed to 24p?
So Matt & ddp, I thought 24pa was mainly for ifand when you intend to transfer to film...
Am I wrong?
Yes. It's a persistent myth, despite all of our efforts here (we KNOW 24p), it doesn't seem to want to die. You should shoot 24pA any time you plan to edit in 24p.
And if you have 24p material, you should plan to edit in 24p every time, unless you also plan to mix it with other frame rates and want to keep the look of those other frame rates.
ddp, you can use 60i for slowmotion in 24p, too. You interpret footage to do the field doubling, then convert to a 24p time base. And I think that even gives you 2.5x slo-motion.
DDP - go here for 60i/24p slo-mo tutorial:
http://rarevision.com/v1/articles/slow_motion.php#
